1G 91+ cruise control
AWD-Tony
6,787
3,748
Sep 11, 2017
Cincinnati, Ohio
I having an issue where the launch control is always active without pressing the clutch. On the 91+ it's a ground switch unlike the 90 where it sees 12 volts. The switch is working properly. I recently ditched the cruise cable assembly and installed a non cruise cable. I'm thinking this is the reason why, so my question is...Do the non cruise cars still have the top clutch switch? If so, how is it wired (where is it wired to)? I'd like to bypass the cruise module and hope this fixes the issue.
Thanks
Tony
"The ECU/ECMLink just wants to see a switch to ground on the ECU input"
As you said that the only difference before/after is removing the cruise control unit, then this could be the issue.
