2G Cruise Control Wiring
SAUBIK
5+ Year Contributor
211
186
Feb 27, 2020
Bratislava, Europe
Hello, does somebody have some photos of all segments of the cruise control system with photos of connectors and complete diagram from input to output?
It can help me much, because i try to make non-cruise car to cruise.
I have EU spec, but cruise On switch above fog switch, cruise ecu and in engine bay near air filter are connectors, so I need to know everything I need to have proper cruise control and under steering wheel is 2 pin connector, but it is connected to key ring in ignition switch.
You can always make your own, I thought about doing this after the cruise control I installed didn’t work.
( Probably because I disconnected my clucth switch )
I thought a microcontroller with actuator could control the throttle butterfly and use PID to measure speed, which you can tap from the speed sensor, this would all be independent of the ECU
