90' oil cooler in a 2g. Pics or tips?
Turbocharged said:
Sweet, thanks.
Just a bit of advice . . . you'll probably have to heat that allen plug up with a torch (propane, mapp gas, etc . . .) to break-down the Loc-Tite on the threads. Afterwords it should twist out quite easy.
the 16MM x 1.5 adapters are for the filter housing correct? I'm using the original cooler, so i need adapters for the actual cooler too. Are they the same size? If not, does anyone know the size of adapters needed for the cooler? Thanks
-Ryan
correct me if I am wrong, but yes I am almost certain they are the same size. M16x1.5
PM me if you find a good deal, I need some also.
Ltr,
MM
Ryan,
Those look to be the right type adapters if indeed your engine has the 16mm metric threads, and your adapting it to an (AN -10) line. Those adapters may come in a crush washer type or O-ring type. I would use the crush washer, that's what was used originally. I didn't see which one these are, in Summit's description. Maybe you could ask Summit about this, or check with Earl's.
Tom
