90 Eclipse GSX
Chris25
62
Aug 7, 2012
largo, Florida
I just purchased a 90 eclipse gsx and the guy i purchased it from said the ecu was and eprom ECU so for the 1g what does that mean as far as tunning?
He told me that the ECU was out of a 91 and had been rebuilt with an eprom he also stated thats the reason the tachometer jumps around from time to time is that a common thing ?
OK I'll pull the cluster today the gas gauge stopped working to so Im thinking the cluster is on its way out
Also with the eprom you can run the chepper Ostrich set up. Not as easy as Link but gets the job done for less money.
Thank you for the diagram I started looking at the wiring harness to the ECU and he had alote of stuff butt connected im going to go through it and solder everything up Im pretty sure its not getting a proper connection thats why its jumping around
Yup thats exactly what my car is doing. And also i was sorting through the engine and noticed the boost solenoid is missing thier is no MBC just a vaccum line running from the gooseneck to the wastegate what kind of issues could that cause and why would he have done that?
No issues at all. It's just running off waste gate spring pressure. Last owner probably had a boost controller hooked up and removed it when he sold the car. Probably lost the boost control solenoid.
