90 eclipse gsx autox
Still cant get my car running. Going through link more I found out my baro isn't being senced. I went through all my connectors on the harness and connectors they are fine, Then I just remembered, wait there used to be a safc on this. So I need to know what connector and pin number it is on the ecu connector side to check if it is connected. I wish they made new wiring harnesses for this car.
Bad news for me. Since I couldn't get SD. To work on my car, I put the maf back on just so I can get it running. Started up right away, but the it was smoking and running 11:1 a/f at idle so I turned it off right away. I checked everything then go to start it up again it spudered popped and died. I cranked it over again and sounded like no compression. Checked the timing to find my exhaust cam gear spun all the way to 10* retarded. did a compression test and no compression at all. Great have to pull the head now.
I am in need of help.After getting everything fixed that went bad, I still cant get my car to run right. It's sounding like only one cylinder is firing. I just replaced my coil pack and spark plugs and it's still doing it. can someone please take a look at my datalog and see if I have everything set up correctly.
View attachment log.2013.08.21-02.elg
any help is greatly appreciated.
It has been to long since i have updated anything on the car. A year ago i got out of the military and moved back to my home town. I have come to the conclusion building a autocross car was pointless in the fact there are no real competitions here. So I've changed some things on the car for drag racing. It now has a hood exit exhaust, gutted doors, and heat wrapped inter-cooler piping. as the car sits, it is tuned on 91oct fuel with 1350cc injectors. After my cage is installed i will be getting re-tuned on 110oct leaded fuel from rebel and am looking for bigger injectors. I will hopefully have the car finished in time for import face off in December.
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid1251.photobucket.com%2Falbums%2Fhh543%2Fracer0091%2FMobile%2520Uploads%2FVIDEO0005_zpswhwisshh.mp4&title=">
