-8an fuel lines to stock fuel filter?
EXTREME PSI : Your #1 Source for In Stock Performance Parts
Hope this helps. I dont know if you want the 8 an on the top or the bottom. But I have a 8an filter using the fittings in the link. They dont make a fitting that goes to the bottom of the filter in 8an. You will have to make your own setup which is what I did.
Why would you want to run -8 to the stock fuel filter? The filter will be a major restriction.
I've read on here that people were still making big numbers on the stock fuel filter. I thought of this previously as well. Price wise the stock fuel filter looked right, if it would stoll give me to my goal. Would you prefer otherwise, what filter setup are you using for a 450 hp range? And thanks for the link.
People make lots of power on the stock hard line, not the filter. Just get THIS.
