JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
The very tip/top diameter of the inducer: 1.9 inches/48.45 mm
The bottom diameter of the inducer (where top of the smaller inducer blades start): 1.99 inches/50.66 mm
Exducer diameter (or diameter of the entire wheel itself): 2.75 inches/69.92 mm
Exducer height at edge of wheel: .235 inches/5.99 mm
Wheel height: ~1.021 inches/25.95 mm
An Evo III compressor is 1.90" / 2.68", so your inducer is the same as an Evo III with a slightly larger exducer. This would still prove to be more efficient at lower boost levels than a Big 16G or Evo III compressor, even without the additional fin.
Sounds a little like the Frank 1 20G....who would want a turbo with a smaller inducer than an actual 20G compressor? Someone that wants better performance at lower boost levels. The 46-trim Garrett compressor used in the Frank 1 and Frank 2 has a much larger exducer than a 20G.
There appears to be no point in the upgrade. The small 16g is more efficient after 25lb/min. the evo3 16g flows more. The big 16g works jsut as well through 38lb/min and chokes a little higher. . . All assuming I have the right map. Considering the big 16g has about the same inducer size, I think I do; since total flow is predominantly determined by the inducer diameter.
