pony2113
- 0
- Feb 9, 2015
Huachuca City,
Arizona
I have both a 6 bolt and a 7 bolt head, both have been removed and never marked as such. How does one identify each?
head bolt hole size. 6 bolt is larger I believe. Take some calipers and measure the ID of the head bolt holesI have both a 6 bolt and a 7 bolt head, both have been removed and never marked as such. How does one identify each?
This is also correct!I believe that one way you can tell is that on the 7 bolt head, the bottom left and bottom right exhaust manifold studs are larger M10 studs. On the 6 bolt head they'd be all M8 studs.
I don't want to say for 100% certain because I'm a newbie as well and I've never seen a 6-bolt head, but what I can say is my 7-bolt head on my 1994 1G has seven M8 studs + two M10 studs. Meanwhile the kits online for the 6-bolt heads all come with nine M8 studs.
Intake runners are a eazy way to tell when you compare them side by side. The 1G head has larger runners than the 2G head (no such thing as a 6/7 bolt head - Late 1G DSM had 7-Bolt cranks, and ran with a 1G heads)I have both a 6 bolt and a 7 bolt head, both have been removed and never marked as such. How does one identify each?
But wasnt it a 1g 7bolt head? I thought the heads were different between them, and then the 2g 7 bolt was different as well.Intake runners are a eazy way to tell when you compare them side by side. The 1G head has larger runners than the 2G head (no such thing as a 6/7bolt head - Late 1G DSM had 7-Bolt blocks, and ran with a 1G heads)
For those 1992.5-1994 1G with 7 Bolt blocks, the head studs are 11mm (like 2G heads) - but the intake runners are still large to match with the 1G intake manifold. 12mm head studs are a feature of the 6 bolt crank blocks.But wasnt it a 1g 7bolt head? I thought the heads were different between them, and then the 2g 7 bolt was different as well.
Your more knowledgeable than I,
This is correct.I was really confused by this myself when I was doing my engine which is why I poked my head into this thread. If I'm understanding you right are you saying there are three different potential heads:
- Early model 1G heads that went onto 6 bolt crank blocks (all M8 exhaust manifold bolts, larger 12mm head stud holes, larger 1g intake runners)
- Late model 1992.5-1994 1G heads that went onto 7 bolt crank blocks (M8 + M10 exhaust manifold bolts, smaller 11mm head stud holes, still w/ qthe larger 1g intake runners)
- 2G heads that also went onto 7 bolt crank blocks (M8 + M10 exhaust manifold bolts, smaller 11mm head stud holes, but with smaller 2g intake runners and other 2G bits?)
