7 bolt arp head studs
50trimgst
151
Sep 6, 2010
Mt.pleasant, Pennsylvania
i have a set of arp head studs and nuts minus one nut, because when i removed the head one of the nuts was a hardware store special. so i just chucked it out the garage cause i figured i could buy just one nut and did not trust a random nut that someone used. i ordered 2 of them off extreme psi and they are both to big... i ordered the 11mm metric nut because that is what there site says the nut is. the nut is just barely to big i mean i can kinda turn it on but it will rock side to side and is visualy bigger than my other arp nuts.. so did i order the right part and they sent me the wrong nuts or did i order the wrong nuts ... again i ordered the 11 mm metric nut they have listed under there 7 bolt head stud kit. and is a grade 8 nut gonna hold up? the car did have a mls steel hg and this random nut with no hg leak.. any input would be appreciated.
Does the threaded part look bigger too, or just the flanged bottom part? I've had 2 different 6 bolt ARP head stud sets and the flanged bottom of the nuts were different sizes but they were both the same 12mm thread.
Do you have a 12mm bolt or tap laying around that you can try to screw that nut on?
Resolved. They sent the wrong nut. They Say arp had the wrong part number idk. But they are sending me the right nuts for free.
thanks..
also just wanted to add that i bought them and there still having the same issue so if anybody id thinking of buying the nuts it would be a good idea to message them and tell them to make sure the vin number matches..
