Resolved 6bolt turbo water lines
Silk90
Dec 4, 2005
Clermont, Florida
i have always ran thrust bearing's and want to run a BB 50 trim but wanted to know how you guy's ran you're water for those of you w/ 6 bolt swap's. i was wondering if maybe there was someplace i could tap into or if i was just going to have to fab up some fittings onto the water pipe and what not. pic's would be great. don't expect much considering it's the newbie section though being the only section i have access to WTF
Solution
not on here often but just thought id post what i did with my water lines for shits and giggles. you can't miss them, their bright blue.
yes sir, i do not see any tap for water line. here are the best pics i found of my water pipe. let me know if i missed something..
EDIT: will look again tomarrow i havent put much time into it but havet seen anything or remember any tap when installing.
I don't have photoshop or I would circle what I believe it is based on the pictures, it should be that tab under the bolt, it should be in plain sight with something able to be screwed into it.
Its there, its on the underside of the pipe, right under the mounting bolt. Looks like you have a bolt in it, or something in there to block it off.
aight, thanx guy's i still have yet to get out and take a look at it due to massive overtime but i appreciate the help.
Solution
