6bolt swap done, gotta a couple electrical and turbo questions
dmc67
290
3
Oct 17, 2004
Middlebourne, West Virginia
ok well first off it wasn't to bad of a job took me 3 days, I got motor from a 90 eclipse and I got a 93.
I got some electrical issues, headlights dashlights or anything wont work unless the car is running andf if i hit a bump they will go off. and my electric windows wont roll down at all. I am thinking it's a ground some where anyone know where i can find a digram of all the stock wiring places?
on the hot side of the battery their were 2 white wires hooked up to the terminal but where does the other end go to?
The waste gate rod runs to the manifold should i be able to move the rod? the wastegate looks like it is pretty rusted up.
Taboo vacuum elimination diagrams have a MBC hooked up is their anyway to do the elimination without a MBC?
any help here would be greatly appreciated.
Danny
Waste gate question...
No. Unless you put enough force on it to compress the spring, you cant move it by hand. Its fine.
Replace the MBC in the diagrams with a Tee fitting.
Wiring Diagrams are in both the Haynes and the chiltons manuals if you have one (with the question I assume you dont, in which case, pick one up its a great investment)
And the electrical problems sound like something loose.
ok thanks for the fast response, I have a Chiltons manual but i can not find it anywhere. I work on my car so many places and I must have left it somewhere.
their's a white plugin by the ECU on the drivers side, the harness I put in only has 10 wires and the old harness had 14 or 17 and it wont plug in, i cant really see where the connector wires runs to b/c they go into a BIG wiring harness up under the gauges. I got no electric what so ever in the car until it is running.
Danny
