6bolt N/T tb vs Turbo tb vs turbo 2G tb
coppersmith
108
Dec 14, 2008
Upper Marlboro, Maryland
which one of these flows the best and which one is worst.I currently have a 2G tb
1g N/T - 60mm TB
1g Turbo - 60mm TB
2g Turbo - 52mm TB
If your running a 2g TB you need to find a 91-94 1g TB (don't get a 90) and port the 2g IM/TB Elbow to get the max flow out of the setup. Here's a good write up on it... RREs  Eclipse 2G Turbo 1G Throttle Body Swap
:dsm:
The shaft seals are also different on the N/T TB but it's the optimum setup for custom pipe setups.
