LandSpeed-DSM
- 2,546
- 81
- Dec 5, 2011
Chicago,
Illinois
E85 isnt a gas at all, its a FUEL. Certain areas have a lot of E85 fuel pumps. You cant call e85 PUMP GAS because it ISNT GAS!
Kiggly is the fastest fwd 4g63 on GAS...he is running race GAS.
Dogboxracings evo went its fastest pass on methonal.
Methonal has a octane rating at 110 octane.
E85 fuel is 102-106 ish
The united states has more 87-92 octane pumps then E85 FUEL so 87-93/94 octane is PUMP GAS. When you inject a higher octane into a motor its no longer PUMP GAS. I do a lot of grudge racing, and IT IS HOW IT IS. If you cant drive your car to any place without needing a JUG of something "special to add to any tank then its RACE FUEL!
My automatic made 604 on straight 92 octane, and went 10.2@134 full weight. NO octane in anything higher then 92 octane.
We get 93oct E10 as Premium here
I run E85 with Water Injection though.
no offence taken on my end, just got a little irritated with your first comment. Yes 10.22 is impressive, what kind of car was it?
My first thought was damn I hope nothing broke off and went through the exhaust wheel
From the nipple on my compressor cover I run a boost line to a T that goes to my MBC for the spool valve actuator, from that T I run a line to another T which then feeds my cut-out and the other MBC for the wastegate. Having a major leak in the boost controlling system caused the spool valve to stay closed by disabling my MBCs to the spool valve actuator and the wastegate. Fortunately for me I didn't replace my 25 psi spring yet
