505 AWHP hx40
That's the data that was logged using DSMlinkV3 and i just homemade copied it over for my own pleasure. look at4200rpm TINY knock, and 5400 knock again. but not even a full count. if you can zoom in and read the top right corner i wrote the max values logged during the dyno pull.
oh-yeah super spicy meth injection
Is that a current mod list? Just wondering since it's talking about a Vpc that's not installed yet. Nice numbers though.
holset AR80, its just the normal one, not divided. its 3'' v-band out tho, so thats cool ;)
once i upgrade from 1000cc to 1450cc injectors i plan on running 33-34psi boost plus another degree or two of timing. my current injectors limit my tune. i should be able to get 550awhp on pump gas no problem. i currently have a homemade 3/4'' throttle body spacer that i use to hold my two 550 cc meth/water squirters. i am also thinking about tapping each one of my intake manni runners to go with individual meth injection. thinkin about puttin a 300cc meth/water squirter in each runner.
my pics under my profile stuff are super old. my pictures look WAY diff now. i got a painted and shaved engine bay, real wire tuck, lots of new parts. lll try to update my pics soon. turbo housing is cool, wire tuck was cooler
Great numbers man!
Just for future reference, you should fill out a mod list in the first post. Just since your mod list on your profile will always be changing and may be misleading to someone looking at this thread in the future wondering how you made this horsepower..
Those are some good numbers. I think you should use a 2g head and a Jmf intake or even the new mangus. You will pick up alot of power.
compressor wheel is stock hx40. i plan on getting the batmowheel for it tho. its way extended tip and is direct bolt in. i was told by bullseye power that the batmowheel should make a 35-40hp upgrade.
So, when you're talking about meth injection are you saying this was done on pump gas + meth injection? If so that's pretty impressive but i would think you should have more injector left if you're running pump + meth. I was at 438hp on e85 on my olf turbo and 1000cc injectors, at around 80-85%idc and 12.2:1 AFR's Now i've got a bigger turbo and at 100%idc and 12.8:1 AFR the math adds out to 546hp (not dyno tested, but based off past dyno numbers and IDC's at the particular AFRs compared to past results)
Anyway, still a very nice pull, i'm just thinking that with pump gas and meth which should save you some pulsewidth you should be able to get more out of the 1000's
