621whp and 553Tq STOCK BLOCK by Ostar Motorsports
nice i hope you hit 9 sec good luck:thumb: with the stock block to handle the maximum pass you can do with it !!
Do you feel that there would be a large amount to be gained by moving away from a bolton turbo due to the excessive backpressure created by E85?
i have given that some thought and i'm sure the car would have some gain by switching back housings but right now it has a great power band for what i rev it to which is 8k. I might loose some torque down low by switching housings. Either way i think it would be nice to get closer to the stock block record running the stock intake manifold and the dsm back housing. I'm making a few changes at the moment and will problably hit the track again next week to see if we can hit better numbers. I'll keep you guys up to date.
actually here is a sheet comparing both at 30psi
Would'nt the hp difference also be affected because you tested with two different fuels and ignition setups? Not just a cam swap?
Figured there was not much diference going from a HKS 264 intake to a 272 intake?
Your absolutely right... I cannot tell for sure what the gain from the cam swap was because fuel was switched over to e85. Great gain either way for what was changed ;)
Oh absolutely! I just did not think the camshaft from 264 to 272 alone would raise your HP that much. Definitely fuel ,your fuel set up for E85 and ignition helped quite a bit. However keep up the good work ,I'm watching to see how much u guys get out of her using the stock intake mani. Impressive!:thumb:
I looked on FP's website and didn't see the listing for the 88HTA turbo you say your running. Care to share the spec's on it? I swear I saw it up there a while back, but it's not there now? I'm looking for lbs / min and what housing (turbine and compressor cover) your using. Thanks :)
The turbo has been discontinued for some time now, the turbo flows 80 lbs/min if I remember correctly and it has the FP bolt on turbine housing and their regular S cover.
