GT3071r stock block dyno run
OstarMotorsport
278
7
Jun 15, 2010
orlando, Florida
Here is a vid of my latest dyno run.
specs are as follows:
stock head (264/272) cams
stock block
stock intake manifold
stock turbo throttle body
fp manifold
gt3071r
aem ems
heres the vid
Nice. Seems a lil low bra. What was your afr? What size injectors ya using? Just a thought.
does it? i mean it is just a 3071 not a 3076 and only has a 53.1mm inducer. with another couple of psi it would have done 450whp which is probably max psi on that turbo before it loses efficiency. Not to mention stock compression is 7.8:1
afr's 11.8 and 780cc injectors
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
