6169sp turbo help please!!
4g63t
1,568
13
Aug 14, 2005
North Iowa, Iowa
Thinking about buying this turbo would it spool up decent on my 2.0 with 8:5:1 compression
Precision Turbo PT61 aka 6169SP aka 500-1450
Compressor Inducer: 61.3mm Exducer: 82mm
Turbine Inducer: 69mm
Turbine housing: T4 Undivided 0.58 a/r 3" V-band outlet
Compressor housing: 4"inlet, 2.5"outlet
Im running a turbonetics 62-1 with 68ar t4 its a 70ar on the intake side right now and it dosent full spool till right before 5k and im sick of it. so would this other turbo spool better?
The smaller turbine will help it a little but o have a 6169 in a t3 .82 housing and I get about 26 psi by 5000 Rpms. This is also with only the e cover compressor. I have a t4.68 housing to put on as well but do not have a t4 manifold yet.
it will be close to the 62-1 in spool time.it may not be worth the money to buy the 6169
I guess a bunch of Subaru guys use them with good results. I think im going to give it a shot for the price i found it, and if it dose not spool any faster ill just sell it. No biggie.
