DSM IN MN
Supporting VIP
- 705
- 23
- May 17, 2009
Wadena,
Minnesota
As you can see from the picture, the shaft snapped or something. This was for my friend's 6 bolt swapped GSX he bought a few months back. We are doing a nice little over-haul to the engine (intake/exhaust manifold gaskets, turbo gaskets, cleaning up the wiring, timing belt, water pump etc.).
I got the timing dead on made sure the back side was tight as VFAQ said, kept it tight on the crank sprocket; everything still lined up; great! Then I put the tensioner on, pull the pin and the above picture is what we got.
Is it that I did something wrong here, or is it just the tensioner quality (possibly)? The timing belt kit is from NAPA (where I work), along with the tensioner. The timing belt is Gates so I do not want to hear I should have gone with OEM Mitsubishi parts; Gates makes the timing belts for Mitsubishi.
Either way NAPA replaced the tensioner for a new one. I would just like to know if there is something different I want to do before trying it again.
Thanks!
This is one of those items that can so easily ruin your engine (bent valves when belt comes off) all for saving a few dollars. You also must compress the tensioner (before installing to insert genade pin) very very slowly. I mean VERY slowly or the seal will rupture/weaken!. [BTW Another no-no is a non-oem clutch throw out bearing - endless threads on this.]
