6 bolt swap help needed - Shopping List
dan ritchie
46
Sep 23, 2003
It looks like the 1g is going to be sold this weekend, so next week it's on (I've got until the 20th to have the 2g running). If this is going to be possible I'll need a complete list of parts put together so I can have everything I need to get started.
The 6bolt I have is complete, and all the 2g's accessories (starter, p/s pump, alt, etc) are still attached to the car.
Obviously, this has all got to happen fast. As far as I can tell, this is a list of what I need, please let me know if I'm forgetting anything (And if you've got any of it please let me know what you're asking):
Parts needed for the swap:
-2g drivers side/engine side motor mount
-2G Starter Mounting bracket
-2G A/C and other belts
-2G sensors - oil, water temp, etc
-2G fuel rail
-2G MAP sensor
Non Swap related parts needed:
-engine hoist (cherry picker)
-tensioner tool
-turbo (14b or bigger)
-2g AWD manual transmission
-2g AWD exhaust (stock or aftermarket)
-6bolt clutch and flywheel (stock or aftermarket)
-balance shaft eliminator kit
-6 bolt timing kit
-radiator fans
-misc nuts and bolts
-various gaskets, etc.
-anti-sieze and threadlocker
-battery
Thanks,
Dan
You pretty much have everything covered. I checked it with my list since i am halfway through the swap and you have everything i have on my list. Good Luck
Thanks, and good luck finishing yours also. I've done a 6 bolt replacement in a 1g, but I've actually never touched a 2g. Seems pretty straighforward, but let me know if you run into anything unexpected. When do you plan on having it finished?
Great list, I may be needing this soon. Good luck with the swap, should go well, if not find some local DSMers! :thumb:
Hopefully someone has a few of these parts so I can shorten the list ;)
Thanks for the feedback. I made the list using the tech pages on this site, and the magnus motorsports site.
There are a few other parts you might need, but my 6 bolt is complete so I'm good.
I know the magnus site isn't working, but I used the wayback machine (www.waybackmachine.org)...
http://web.archive.org/web/20031227080958/http://www.magnusmotorsports.com/1g2g.asp
Good luck man! I just finished mine a few months ago and I know what type of blood, sweat and tears you're about to endure. :)
Mine will be finished on wendesday if everything goes according to plan. Today i finally got to order everything else that was needed :) Am getting excited since i haven't had the car running for 3 months LOL
i dont know if anyone has mentioned but youll need your cam angle sensor wired properly. :dsm: yeah my dsm has been down since sept 04. should be running soon this week or next ROFL
Here's my list of needed items, I just ordered my dsm cd with caps, so within the next couple days I should beable to update with part #'s and also prices from jnz, or from a dealer with discount.
Updated MARCH 23/05
6 bolt water line
6 bolt oil filter housing
6 bolt oil pan (USED$??) (new SBR $100)
6 bolt oil pick up
6 bolt rear main seal
6 bolt timing belt tension arm
6 bolt timing belt cover
6 bolt water pump (MD972052)
6 bolt flywheel (ACT) (PROSTREET$270 tax/ship)(Reitman $410 with scattershield)
6 bolt front cover (MD129347)
Driven Gear (MD174582)
Drive Gear (MD174581)
6 bolt timing tensioner
6 bolt trigger plate
6 bolt arp head studs($90 summit racing)
Prothane Motor Mounts($66 Summit Racing)
Head Gasket
BS Eliminator Kit
fuel filter
spark plugs ($12)
spark plug wires (ngk $40)
Timing Belt items 6 bolt
92-94 cas (used????)
RRE Cas plug and play ($80)
External Oil Cooler
Crankshaft spacer (md128107)
let me know if I forgot something Will update tomorrow, with prices on parts with #'s and try and find some more part #'s.
ps this is for a 6 bolt with 2 g head.
what usually comes with a 6 bolt complete swap?? all of that or am i still going to be missing some?
hey you can also buy or make and egr blockoff plate if you want. im not sure if your running stock ecu or not. but i removed all my egr stuff. i am running an ems but i am not sure if you have to be running an ems to remove your egr stuff. It is somethign you should look into though. :thumb:
FYI: When you order the scatter shield, which is a very good idea, you need to order the 2G 7 bolt model. The head dictates the fit not the short block.
Three Speed
