6 Bolt Manley rods with 22 mm pin hole?
streetdsmpwr
322
3
Oct 13, 2009
Canton, Michigan
I bought a set of used Manley H-beam rods from a member here and he told me they were 6-bolt rods with a 22 mm wrist pin hole. The hole measures in at 22 mm, but could you guys help me with figuring out if the big end will work with a 6 bolt crank? I have a set of 7 bolt rods and the caps are 2 mm thinner than the Manley caps. Is this a good sign? I'm assuming it is, but I just want to make sure. Thanks.
Yes the 6 bolt rods are thicker across the crank end than the 7 bolt rods
6Bolt wrist pins are 22 mm
7bolt is 23mm wrist pins
