5th Gear Trouble
Smokeyg1045
Jul 11, 2009
Marion, North Carolina
Hey i am having a problem with my 96 gs when selecting 5th gear it will stay in gear if you press the gas once but if you let off of it and press again it will pop out of gear...happens even more at highway speed 55+ 3k rpm i have been to 3 other forums trying to solve this problem and the only solution i have got is trade it in, and i'm not looking to do that. it has a short throw shifter in it that the guy before me put in and he also told me that the tranny is out of a 97 talon any ideas?
Bent shift fork or damaged synchronizer.
Transmission shop could repair it, or more cheaply, grab another transmission from the junkyard or classifieds.
what about adjusting the shift linkage could that be a possibility and if so how do i adjust it?
It's the synchro. I had the same issues after a clutch replacement. My reverse gear popped out all the time and I put in a new set of synchros and it solved the issue.
This can also happen with bad trans mounts. When you push on the gas it will pull your shifter down and when you let off the gas it will pull your shifter forward. I've had this problem and everyone kept telling me I needed a new transmission and the mounts were the problem, engine torque was pulling on shifter cable and pulling it out of gear. Also make sure all of your shifter and tranny bushing are in good shape and that you have enough tranny fluid in the tranny, which is kind of a given, but hey, have seen it a million times. Someone thinks they have a tranny going out, but there is no fluid in it or it just needs changed.
-DsMgIrL078
Reverse doesn't have a syncro.
I'm having this same exact issue. Just started after doing a turbo swap but I know that has nothing to do with it. I have a feeling mine is a mount. Glad I found this thread. Guess I'll need to be checking it out. I'll post back my results when I find it. It all depends on how I hit the gas as to if it pops out or not. Tranny shifts perfect in every gear though.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
