trouble starting. rebuild??
Most aftermarket rods use a bushed pin the 420a are press fit so it will not work with stock pistons unless you can find a set of rods for pressed pins.
^This.
But I currently have a set-up that uses stock rods and 10.5 JE's. I had the machine shop bore out the small end of the rod, to accomodate the full float wrist pin of the JE's. Of course, the shop will charge you extra for that and then you will still be limited to the strength of the stock rod. One of the reason's that many just go with the Eagles when they rebuild for turbo.
As for oil pump, I would recommend OEM. The HD Melling has a higher failure rate than I like to see (you could ask slo2g on here about that, LOL). And yes, you should do the water pump and timing components on a rebuild (along with bearings, gaskets, pistons rings etc.).
I don't know if you have read it but here is a good link to how to rebuild that might help you get an idea of what you need;
2GNT.com - A_Proper_Rebuild
MB
MB
ive just came in from getting the head off the block. the valves seem ok. just really cruddy looking. and the tops of the pistons is the same deal. tomorrow the motor is coming out.
(im waiting on a engine hoist. and a engine stand) as soon as i get those i will know the extent of the ring damage as well as any damage to cylinder walls.
thamks again bullett. youve been a good bit of help. no haynes book for me!! LOL. someone stole mine.
  • For sale 2g 99 2G parts
    up for sale 2g items! everything came out of a 99 eclipse throttle body 70 shipped stock 450cc...
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
