4G64 - a hole in the oil gallery, normal or abnormal?
tak
Feb 3, 2014
Albany, Oregon
Hi,
I'm working on balance shaft elimination (partly because the silence shaft drive gear has caused some troubles since the last rebuild). When I took the front cover off, I came across this hole in the oil gallery (shown with a red arrow below).
This gallery is located behind the front cover on the 4G64 block as indicated by the red circle below:
Could anybody tell me if this is normal or abnormal? If abnormal, should I try to repair it with JB Weld or something? Thank you for your advice!
Abnormal. .......................................................... Abbie Normal
My first impression is that it wouldn't cause any issues at all. If I let my mind wander, I can see how it could potentially cause problems. Personally, I would try to fix it, just for the peace of mind.
Thanks for your replies! @bryanwheat, that sounds reassuring. Do you know what that passage does/goes to? On the front cover side, it seems like those two "compartments" separated that seemingly breached wall are connected together. So I was thinking maybe I don't need to worry about it. But I wanted to check with the knowledgeable crowd to see if anyone has seen this before or know something about it.
I might think thats just an leak down passage. If its an high pressure passage i would'nt let olie leak like that. jafromobile on youtube has an video about the oil passages, if i'm remember correct he explain those passages. Look it up, its on the crankwalk examination video.
