2G 4g64 a/c compressor
I imagine it's the same compressor as the 4g63 models. 4 bolts and it's off. The hardest one is the one that sits closest to the steering shaft. I've always removed the intake manifold to get the compressor out, ut if you're ok with draining your transmission, pull the driver side axle out and you might be able to drop it down between the engine and subframe. I've never done it that way, but it could be possible.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
