Spyder 4G63T 6 bolt into a 2G Eclipse Spyder?
EljefeDSM
Feb 8, 2023
Saratoga Springs, Utah
Hello, I’m considering a 6 bolt swap on my 99 spyder. I wanted to get a fmic kit for it but not sure if I need the same as if it was a 7 bolt. Anyone know which kit I’m supposed to get? Thank you.
I can cut the pieces, I think I know someone that can weld them. What about the blow off valve? You keep the same?
Thats up to you. If you're talking stock 2g then no you can't keep it. Look at how it mounts. This is a fabrication project. How comfortable you are with that is determined by your skills . We kind of can't answer that for you
