4g63 na ecu
steven_esi_bui
Dec 12, 2012
milwaukee, Wisconsin
So ive recently purchased a automatic 92 talon 4g63 n/a but the ecu went bad, and i was wondering what other ecu's are compatible with this car? Since i cant find any 4g63 n/a in any of the junk yards around my area.
ecu numbers are (MD153354), (E2T35372E).
Sounds like someone swapped the cover on that ECU in the past. A MD153354 is for a 6 cyl SOHC 6G72.
A 92 NA Federal 2.0L would have had a MD166255 (E2T36572) ECU in it and that's what you are looking for. If it's a 1.8L it would be a MD159561. California cars used different ECUs. http://simon.chi.il.us/ECU/ECUID.html
Since it ran before I expect there is a 4 cyl ECU inside the case. Open it and see what is printed on the white ECU connector. The 4 digits match the last 4 of the E2T number for the original part.
i just opened the case and the numbers imprinted on the ECU connector are 6572, so youre right the previous owner messed with the casing. thanks for the correct numbers.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
