4g63 Beehive Valve Kit [Merged 10-8]
Is it necessary to replace any other hardware in the valvetrain to support continuous 10000+rpm? Such as the lifters, rockers. How do you prevent the lifters from going solid?
On my new setup i have 3g lifters and the beehive springs, and it is just fine. My cams are not that aggressive yet, we will see what happens when i go to a crazy aggressive cam.
Evo 8's use beehive springs and the retainers are super light. Plus they drop right into a dsm.
Can anybody else confirm that the evo 8 has the beehive springs?? The redline is set at 7k
I know that for sure. Mitsu is to cheap to put those springs in....but did they really?
Yes, it is confirmed...
Also does anyone know what Evo retainers are made from??? I've played with titanium retainers (crower, bc and revolver) and these evo ones are much, much lighter... All 16 tip the scales at a whopping 2.2 ounces. Also the springs themselves are each 0.6 ounces lighter than dsm. The sodium filled exhaust valve (also confirmed:thumb: ) is 0.3 ounces lighter than a dsm exhaust valve and the intake is the same between evos and dsms.
The weight pulled from the valvetrain allows it to operate more efficiently and maintain good valve control at higher rpm levels. Remember, the valvespring has to overcome not only the inertia of the moving valve, but also its own weight and inertia.
Any of you guys hear about the new valve springs by Comp Cams? Bee Hive springs. They are suppose be better than dual springs. Check this link out and tell me what you think. You think that we could get some valve springs like that?
http://www.performanceproductreview.com/Base/Files/PDF/Articles/PPR2006/Beehive.pdf
Wouldnt we just have to know the dimensions of our valve springs and match em up? Does anyone have those dimensions?
I was under the impression that the Evo 8 valves (both intake and exhaust) were nitrate-filled.
Sodium, sodium nitrate, natrium, I think they're all similar or they achieve the same goal. I don't know anything about chemistry, so I could be wrong.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
