tbird
- 170
- 2
- Nov 10, 2002
I need some tips on how to change the valve seals... im gonna be doing this for a friend how much time can i expcent doing this. and what tools will be needed.....
You do have to pull the cams to get at the valve springs. I recommend doing a balance shaft delete while you're at it.Appreciate the answers. I thought I had to pull the cams to get at the valve springs, thats great that I don't. I bought this car as a second car/project car and my wife is already complaining about the car being a money pit as she calls it. Also I'm replacing the water pump, drive belts, timing belt, and pulleys/tensioners please let me know if you would recommend changing anything else while the timing belt is off.
Thanks again.
.is there an instruction place that shows u step by step..i cant find it on vfaqIts not to bad. I've heard of people not having to take the head off but I have not personally tried doin it that way
i got the head offThe job itself isn't hard. But you do have to have a tool to compress the valve springs. Otherwise all you'd need is that tool, a magnet, and something to pull the seal out of the head. However, i don't know how difficult it is with the head in the car.
It's not hard for me. But it would be hard for somebody who doesn't know how to do an oil change without asking questions. Basically, it depends on your experience.
thanks ill check it out
It is on vfaq under the engine section: Valvespring compressors
where can i get his tool..Best 80 bucks I ever spent.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ZFTaeu4GIPo&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ZFTaeu4GIPo&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/uh53RyVeHPA&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/uh53RyVeHPA&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
