valve stem seals
Daaan
229
Aug 15, 2007
Courtice,
I bent all my intake valves, so i bought a new cyl head from the junk yard. Ive had it machined and replaced the cam seals. should i also replace the valve stem seals? i have a 1992 Eagle talon fwd.
thanks everyone :talon:
oh and what would that end up costing me for the valve seals?
It wouldn't hurt while you're in there, but the question is if you have the valves out or not.
They are fairly cheap and easy to replace, the only problem is that they're underneath the valve springs.
Change out both valve guides and valve seals. Im now in the process of getting my head off and sending the head to the machine shop to replace those two. I did not replace those on the first head rebuild. Now a guide or a seal has gone bad in one of my cylinders with oil dripping in it. Stupid me.
