2G 420a Ignition coil and camshaft wiring
Chris3897
Oct 2, 2024
Sayre, Pennsylvania
I think I may have switched my coil pack and cam sensor wiring around. I have the book but can't really understand the diagrams.
I have a 95 420a NT right now I have R/B, brown,&B/BL for the coil and Y, BG, &BlP for cam sensor. Can someone please help me confirm is this is correct and if so what order they go in on connector? Thanks you
Coil. Cam
Looking at my '95 manual for the N/T diagrams there should be the following:
Camshaft Position Sensor -
Pin 1 Yellow (+9v Power from ECM)
Pin 2 Black/Green (Sensor Ground from ECM)
Pin 3 Blue/Red (Signal PCM pin 26)
Crankshaft Position Sensor -
Pin 3 Blue/White (Signal PCM pin 25))
Ignition Coil -
Pin 1 Brown (PCM pin 41)
Pin 2 thick Black/Red (+12v Power from ASD Relay)
Pin 3 Black/Blue (PCM Pin 21)
Thank you greatly appreciate it.. sorry it's taken so long to reply, I'm just now getting out to the garage to get this wiring finished up
