1G 4 turbo bolts... NOT
Red Rider
103
47
Aug 12, 2009
NW, Connecticut
Getting closer to getting the head off. And I see this.
3 bolts and a stud with a nut. WTF??? Is this the way the factory did it? Was my car built on the day they ran out of turbo bolts? Sure hope all 4 come out.
Interesting though-
The most logical reason to me is that it makes it easier to assemble, as the one stud acts as a guide. But then I think about all the places where assembly is a complete Pain on these cars, and in much less accessible places than front and center under hood, so that kind of pops that idea balloon.
sometimes a stud/nut combo is used when there isn’t room to stab or remove the bolt due to access, but again that seems not to be the issue here.
Oh well, anyway, yours is stock, just as Mr. Diamond-Star intended.
Interesting though-
But you're right, thats the only reason for using a stud/nut combo on these cars.
The stud acts as a guide like you already said. Not because there isn't much room, but rather because it makes it easier to align the gasket between the 2 flanges correctly, like on the head/exhaust manifold, manifold/turbo, O2 housing/turbo or TB/Intake manifold for example.
The guide concept occurred to me, but if the stud won't come out you might have a larger pain than easier alignment on assembly.
Anyway, I started hitting these fwd and rev with 50 lbs in the air impact gun. Incrementally increased the pressure. The nut let go at 50lbs, 2 bolts let go at 75 lbs, last one took 90 lbs and spun out. At this point I'm giddy every time I get a bolt or nut off without shearing it.
  • For sale 2g 2G Belt Molding Set
    2G Belt Molding Set $170 + shipping & paypal fees** NO peeling or chrome showingYou must be...
  • For sale 2g 2G OEM Knock Sensor
    2G OEM Knock Sensor $85 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g 2G 3rd Brake Light With Trim Panel & Hardware
    2G 3rd Brake Light With Trim Panel & Hardware $85 + shipping & paypal feesYou must be...
  • For sale 2g 2G Black Passenger Air Bag
    2G Black Passenger Air Bag $85 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Manual Shifter Base with Short Shifter
    2G Manual Shifter Base with Short Shifter $75 + shipping & paypal feesYou must be registered...
