ECMlink 3rd gear WOT pull on E85
Type1DSMr
1,116
164
Jul 27, 2014
Jasper, Indiana
1). Any boost, vac, or exhaust leaks? Boost leak tested 5psi above your max boost with no leaks?
Nope tested at 25psi takes about 5 mins to bleed out
2). Verified mechanical timing?
yes
3). Verified base timing?
yes
4). Ignition system
COP or Stock Coil: Stock coil
Wire brand and Age: Ngk
Spark Plug brand, type and Gap: Ngk bpres 6 at .28
5). Motor health (Compression Test)
Cylinder 1:180
Cylinder 2:175
Cylinder 3:170
Cylinder 4:175
Done less than 2 weeks ago
6). Performed basic throttle body adjustments?
Idle Switch: yes
Throttle Cable: yes
TPS: yes .63v
BISS: yes
7). Compression ratio stock 2g 7 bolt
8). Any known bad sensors or brittle wiring? No
9). Any DTC/CEL codes? No
10). Electrical system
Car off (not running): 11.9 to 12.2v
Car running: 13.5 to 14v
11). Base fuel pressure and injector values
Base Fuel Pressure: 43.5psi
Injector Size (cc/min): FIC 1100cc Hi-Z
12). Properly calibrated and configured wideband sensor
Sensor Brand: Innovate MTX-L
Calibration Date: less than 2 weeks ago
13). Type of fuel
Type: E85
Percent of Ethanol: Hopefully 85% haven't tested it
14). Watched ECMlink how-to videos? Yes
Here's a 3rd gear pull from yesterday on my first fill up on E85. I have since changed the mafcomp sliders to match the 12 afrs since during the pull it was going down to 11.4 or so. Is there anything else I can do to improve the performance. I have also switched to bpres7 plugs since pull. Turbo Evo 3 16g, Fuel mods Walbro 450 e85, FIC 1100cc Hi-Z, Fuelab reg and filter. I will soon be going to SD and using a gm flex fuel sensor. Just ordered the PnP harness from ecmlink. All other mods are in profile or ask if more information is needed.
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 2g NEW OEM FWD Fuel Level Sending Unit
    2G NEW OEM FWD Fuel Level Sending Unit $85 + shipping & paypal fees* NOT the fuel pump hanger...
  • For sale 1g 1GA OEM Corner Lights
    1GA OEM Corner Lights $65 + shipping & paypal fees* all mounting tabs are intact * the...
  • Wanted WTB 1990 AWD manual Talon Transmission or shifter Forks
    I need a 1990 AWD 5 speed manual Transmission. The transmission has all the shifting forks...
    • 90rallytalon
  • For sale 1g 1g dashmat. Black.
    1g dashmat. Black. Overall good condition. Does have a tear where the dogear flap is on the...
