3g mc bb in 2g parts list
kinda-stock
55
Jun 4, 2016
jefferson, Louisiana
so there are links to 3g mc and booster into a 1g...any difference for the same swap into a 2g?
Also anyone has correct part numbers for the 3g mc and booster. RockAuto and the rest list tons of different part numbers.
Are we basically looking for Non ABS NON Traction Control Master Cylinder and Booster for a 2002'ish Mitsu Eclipse RS?
Not sure if you are still looking for this, but in case anyone else is... any 3G from 2000-2005, no ABS, no traction control. If you are deleting your ABS, you will need a fitting and will also need to bend a line, since one of stock 2G lines doesn't line up to the 3G MC and has a different fitting. JNZ Tuning has a kit with SS lines and comes with the option of the fitting for the 3G MC.
There is a lot more info here - http://www.dsmtuners.com/threads/3g-brake-master-in-a-2g.459407/
