3/8 npt vs 3/8 bspt
Wanagofast
108
3
Nov 12, 2013
Newman lake, Washington
I'm confused on feeding the turbo from the oil filter housing. My question is, whats the difference between the Bspt and Npt fittings? could i use 3/8 npt instead of 3/8 bspt?
I checked STM's page and didn't see one, but yes I would buy from a reputable source. If I can find it, I will post that link. Maybe Extreme PSI or Forced Performance. I can't remember which one I found it on back when I was putting mine together but I will check and report back.
http://www.extremepsi.com/store/product.php?productid=17334&cat=0&page=1
Check this link
IMO, you could use 3/8NPT in BSPT.
3/8 BSPT
Major thread diameter, 0.656".
19 Threads per inch.
3/8 NPT
0.675"
18 TPI
As with all tapered threads, use some thread tape. It'll work but I would get the correct adapter...
The npt in bstp will crack the OFH if screwed in too far. I use a 90 adapter and a bstp to npt adapter to clear my lower ic piping.
If youre careful, you can use NPT in a BSPT hole. I deal with fittings for a living, and Ive even got two 3/8 NPT x -4 JIC 90* adapters in my own filter housing with no troubles at all. Just dont go crazy when youre tightening and balance between desired fitting position and tight.
Alright thanks everyone for clearing that up! Yeah i think i'll go with edged on this one and support the vendors. Plus its hassle free !:thumb:
