Resolved 2GNT 420A alternator bolts
zaiden
Mar 1, 2011
spiceland, Indiana
i need the alternator bolt sizes & everything that just holds the alternator in place, mine have recently fallen off & came undone somehow so i need all the bolts & nuts to replace them, iv tried going to the junkyards around here & all the ones iv found are just rusted to crap & useless plus i figured new ones would be best since iv also got a new alternator, also since i dont have the old ones or cant get ones off a junk car i dont know the sizes at all, please help!
PNC -- Mitsubish Part Number -- Part Description -- Specifications
14788P -- M06101448 -- Alternator Nut; Hex Nut-Coned Washer, Nut and Washer; Alternator to Adjusting Bracket Nut -- M10 x 1.50mm pitch
14799U -- M06504286 -- Alternator Bolt; Header Point Screw, Adjusting Screw -- M10 x 1.50mm pitch x 50mm long
14799S -- 06504880AA -- Alternator Bolt; Square Head Screw (previously M06503296) -- M10 x 1.50mm pitch x 105mm long
14788S -- M06502691 -- Alternator Nut; Hex Flange Lock Nut; Alternator Harness Attaching Nut -- M6 x 1.00mm pitch
14788Q -- M06101510 -- Alternator Nut -- M10 x 1.50mm pitch
14799P -- M06503364 -- Alternator Bolt; w/ Retainer, Alternator Pivot -- M10 x 1.50mm pitch x 105mm long
14799Q -- M06101512 -- Alternator Bolt; Hex Head, Screw and Washer; Alternator Pivot Bracket Mounting Bolt -- M10 x 1.50mm pitch x 45mm long
Those partnumbers are the same for a 98 GS NT yeah? I'm needing the adjusting bolt
They are problably dealer only bolts then. I just came from home depot and pretty much grabed every bolt and nut close to those specs I'm about to find out if they work
Sent from my T-Mobile G2 using Tapatalk
Hey Guys -
Wanted to say thanks for this post, since I was missing the Adjusting Bolt on my 99 420a RS. I was able to go down to Lowe's and grab what I needed, however there is one correction.
On my car, the part listed as 14799U, was actually an M8 x 1.25, not an M10 x 1.50. Maybe someone lost the whole assembly at some point, and grabbed the other bolt from something else, but whatever the reason, it's different.
Also, in doing this, found that the slotted part of the bracket was actually broken, and a piece was missing, so I need to find another one.
Anyone know where I can find another bracket, without having to go to a yard and pulling it myself?
Thanks again!
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
