2g window trim (above door), what do you guys use to recoat it?
napalm
64
Apr 10, 2010
DSM free, Missouri
I saw a handful of threads discussing new trim pieces, sanding the old ones, etc. but never really saw what anyone used on the recoat.
krylon fusion? rubberized paint? regular rattle in gloss or semi-gloss? Should you bother with a clearcoat?
I have t he same problem with my 1G. Going to be repainting it sometime next month. What I'm going to try is using the stuff you dip the handle of pliers and screwdrivers into. I tried painting and old piece but it didn't look right compared to the rest of the trim. Interested to see what other solutions tuners have came up with. As far as clear coating only if it is gloss black instead of flat black.
Old thread but I thought I'd throw in my two cents.
On my Honda I removed the peeling stripping with a razor and sand paper and applied electrical tape and cut the edges. A temporary solution but it's very cheap and doesn't look horrible ( As long as you trim it :ohdamn: . )
trim piece like that you can use either plastidip or rattle can. it is really your preference. just know that with plastidip you may have to touch it up or redo it entirely
Luckily I don't have to worry about the drip rails :D but I do have to worry about the trim going around the base of my top. I used paint on those, but once I put the Spyder into overhaul mode, I'll be using plastidip for them.
i gust sanded it lightly cleaned it then sprayed it with a paint can . you will have to do several coats and sand between coats .
  • For sale 2g 2G Belt Molding Set
    2G Belt Molding Set $170 + shipping & paypal fees** NO peeling or chrome showingYou must be...
  • For sale 2g 2G OEM Knock Sensor
    2G OEM Knock Sensor $85 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g 2G 3rd Brake Light With Trim Panel & Hardware
    2G 3rd Brake Light With Trim Panel & Hardware $85 + shipping & paypal feesYou must be...
  • For sale 2g 2G Black Passenger Air Bag
    2G Black Passenger Air Bag $85 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Manual Shifter Base with Short Shifter
    2G Manual Shifter Base with Short Shifter $75 + shipping & paypal feesYou must be registered...
