2G w/ e316 creep solution: external on collector of manifold
rowlex
1,298
28
Apr 12, 2003
Everett, Washington
Since I was unable to find much info on this I will post what I have :)
Manifold is made of cast STEEL not iron, it is easy to weld to. The shop I had weld this had no trouble welding it and the beads are b-e-a-u-tiful. I have not run the setup on the car as I have not had time to do it yet.
My E316G was boost creeping to 26+ psi I had it externally dumped off a 1.5" dump tube. I had not ported the wastegate hole and didn't want to bother with it.
any thoughs, concern's, comments are welcome :)
The shop milled the divider in the collector a bit to fit the 38mm pipe. The pipe is welded on the inside of the collector as well as on the outside.
Talonman said:
34mm flapper mod and/or a tubular 02 housing dont fix evo3 creep?
I dont have the 34mm flapper. my car creeped past 25lbs. I had ported the inlet to the wastegate path but nothing done to the actual wastegate hole. I have a tubular o2 with a 1.6" diameter dump on it.
    • george bromwell
    • pma1123
    • Sdcryan1
