New SBR Manifold w/ External Wastegate
Syndicate13
1,511
31
Jan 5, 2003
Ft. Myers, Florida
I said I was going to do this because when I was asking questions I could not find the answer I was looking for. Everyone knows (or should) that an external wastegate is a lot more effective at controlling boost than an internal. Most people are cheap and unless going full garrett there was no cheap or easy way to go external with a Mitsu style turbo. SBR recently released another iteration of their cast manifold with a built in 38mm wastegate flange. I have yet to find someone else running one with an external gate so I'm posting this here for anyone else who was looking for the same answers I was.
First the manifold. It came packaged nicely and looked great. I ordered it ported of course, no use buying new parts and not getting the best right? Port job was smooth and complete, I had heard some rumors that SBR was not going into the runners, merely porting the entrance and the collector area. This was not the case with mine and I believe not with anyones. Here is a pic next to my mildly ported 2G manifold, don't mind that crack.
The sole reason I decided to go with this manifold was the ease of mounting an external gate. No messy welding to have crack on me, no wrestling with some custom O2 mount setup that is subject to the same creep problems from improper porting of the turbine housing, just simple effective, solid boost control. I will tell you now that on my 2G I had to relocate my dipstick tube slightly but the Tial 38mm clears the PS pump without a problem. My stock AC fan was melted from an exhaust leak so I removed it and it will be replaced with a slim style fan anyway. The stock AC fan will not fit with the wastegate mounted so take that into consideration if you wanna go this route. One thing I noticed about my manifold was that the bolt holes on the manifold were slightly wider than the holes on my wastegate, requiring me to make the holes on the wastegate slightly larger to make some room. I don't know what Tial wastegates are made of but it's some tough damn stuff!! After this little modification it went on fine. SBR makes the flange at the head thicker to provide additional clearance from the waterpipe for turbos with large compressor covers. I am running a Green and the waterpipe required some "convincing" to let my Green occupy it's space. The rest of the install went smoothly and I have no real complaints, other that SBR forgot to include my 7cm gasket and even after calling I still have not received one. Lucky that I have the DSM Professor as a close neighbor and he had one laying around. Here are a few more pics showing the whole thing mocked up on the bench and finally all together in the car, as well as a comparison of the small 16g and Green.
I agree. Excellent review. I have been waiting for fitment feedback on these new manifolds as I am eagerly awaiting my Tial wastegate setup on my car.
How is your wastegate dump tube routed? Does it clear your FMIC pipes?
i want to know if the stock heat shield can be rigged to fit over that. maybe cut a section for the waste gate. :confused:
The bolt holes make it look like it accepts the factory heat shield, but you'll have to cut the wastegate area out.
We chopped up the stock heatshield so it would fit but we hacked so much away that it probably wouldn't do much. I may make one out of something else to put on eventually. I plan to route the dumptube forward and exit between the radiator support and my LICP. There is plenty of space there and after we mock it up with some flex pipe we'll have a hard pipe welded up and wrap it to help with the heat.
How bout some Wiseman status? LOL :sneaky:
Why did they cast/machine/port the center flow divider down? If thats the case, it is by far the single worst thing you can do for spool up & power. Maybe it just looks like it in the picture. The pic looks like it is taken down almost 2/3rds. I hope that is not the case, cause I'd otherwise be very interested in it.
It was done that way by them. I too am a litle curious about it, we'll see how it does I guess. Maybe someone from SBR can speakup as to why.
Looks good :thumb: . I am also doing this setup as soon as my SBR manny comes in. I order it from Martin (The speed factor) who had some on sale. But hasn't arrived (been waiting almost 3weeks) Anyway can't wait for this bad boy to arrive. I have my TiAL WG and O2 Housing ready to bolt on.
Is there anything I should look out for when installing it? I'm dumping on the side of my bumper :rocks:
What about performance number differences? Quicker spool up? Better throttle response?
I'm thinking about getting one of those to decrease my turbo spool time. Does it help?
99gst_racer said:
A wiseman would know that product reviews belong in the Product Reviews Forum. OMG :shhh:
Doh! I didn't even know we had one of those. :coy:
As for spool and performance, I really won't be able to comment, a new turbo went on at the same time and I haven't even driven the car yet. If you notice in the last pic there isn't a transmission in the car. One of the wear pads on my TRE Evo3 forks fell off, consequently the fork wore 40 thousandths off my 3/4 sleeve so I need a new synchro. TRE was closed Friday for a long weekend so I'll have to overnight it on Monday. Oh well.
not to hack this thread but whats the difference between this manifold and thier SS tublar peroformance wise
mitsuclipsegsx said:
did you recir it,or dump
Straight to the ground. I have off Thursday and I'll steal my friend's camera and take some better pics. I need another fan though, my car doesn't like idling in traffic with just one.
does anyone make an 02 housing that will work with this set up (sbr manifold and tail 38mm external wastegate) that recirculates the external gate? (sorry for a somewhat thread jack)
from what i understand i been wondering too, if you want to recir it you have to customize it or have a exhuast shop weld it.I heard its hard to weld to a stock 02 houseing, so i guess most people dump it, but what i am gonnna do is what rowlex did he had punishment 02 dump, he had the dump cut off and welded shut and welding it back to 02 hosueing , this is what he showed me
i wanted to get a setup like yours... i didnt see a answer for the above post, i was wondering how it helped spool time too???
