jtmcinder
DSM Wiseman
- 5,402
- 96
- Nov 4, 2003
Iowa City,
Iowa
Yeah, well, the decrease in compliance you'd get from switching the OE bushings for poly makes it better to go with those over ripped OE, anyway. Oh, well.
Depending on your reading of the Street Mod rules, there may be a very useful change to make when you redo the anchor bolts. The math says that extending the length of the anchors, such that the eye is moved downwards, will not only get you a bit more camber, but will also steepen the bump-camber curve so that you gain more negative for the outside front as the car rolls in a corner, while also taking out more negative from the inside front, so it's a win-win.
That's sound like a really good idea.
However wouldn't that also increase the amount that the ball joints are extended beyond their full range of motion already? That might end up being a bad idea for those using the SPC arms.
Now the question is just how big would you really want the spacers and will it cause you to tear the mounts out?
Kevin
I welded a washer around the top posts on each side of mine to brace it some.
Here is what the strut tower looks like deconstructed. You can see the anchor mounting post there. Not the best design.
http://www.dsmtuners.com/forums/152098615-post31.html
How much more torque is being introduced into the system if the eyebolt is extended half an inch, as far as destruction/detachment of the tubes is concerned?
Com'on, man. You can do this on a napkin. Have some self-confidence. It's just lever-arm math. Take the new distance from the center of the eye to the center of the tube and the old distance, divide, and that's the multiplier for the new level of torque. Based on my memory for these things (warning: see previous posts about the 1970s), you're probably going to increase the torque on the tube by less than 20%.
This is being anal, but you forgot to take into account the angle at which the force is applied.
Regarding the strength of the upper a-arm mounts, does anyone remember the Neuspeed upper strut bar? It was unique in that it mounted to the rear a-arm eyebolts. I always thought this made more sense than a strut tower mounted bar on a non-McStrut suspension like ours.
You should see what I do to coasters when I'm in front of a pint. Somehow the physics begins to pour like the golden goodness that is a good IPA.
But I'm just gonna run out in my skinnies, toting tools and such at 6AM to go take measurements? I'm sure I already abuse my interpretation of "reasonable expectation of privacy" as far as the neighbors are concerned.
I wanted to inspire discussion. Something for those following along at home to do.
However, the variables are not all known. Do you, Jt know the exact length of that tube? Now that I've had some coffee, and it's no longer 6AM, I've done a little bit of napkin math and have concluded that the tubes are 2.25" or 57.5mm. I had crude means but I'm feeling self-confident.
(A)Tube length = 5.75cm
(B)Dist. from center of eyebolt to bottom of tube = 4.20cm
Dist. from center eyebolt to center of tube = ((1/2)(A))+(B)
= ((1/2)(5.75))+(4.20)
= 7.08cm
(C) = 7.08cm
New dist. from center of eyebolt to center of tube = (C)+(1.27)
= (7.08)+(.5)
= 8.35
(D) = 8.35cm
Torque = Force x Dist.
Force = Arbitrary quantity such as 1000N
(D1) = 7.08cm
(D2) = 8.35cm
T = (F) x (D1)
= (1000)x(7.08)
= 70.8Nm
T= (F) x (D2)
= (1000)x(8.35)
= 83.5Nm
(T1) = 70.8Nm
(T2) = 83.5Nm
%increase in torque = ((T2)/(T1))-(1)x(100)
= ((83.5)/(70.8))(-1)x(100)
=17.9
There is a 17.9% increase in torque applied to the eyebolt mounting tubes when extending the eyebolts downwards 0.5".
If this is at all correct then it looks like the increase in torque is less than 20%. What do you think, Goblin? Can the factory welds take an additional 18%? Were the welds on the tubes exhibiting stress when you dismantled your towers?
I've also concluded that stock eyebolts should work fine as replacements or substitues for the SPC supplied eyebolts. They are slightly wider but should pose no issues. Not sure yet if the bushing dia. matches.
Maybe it would be fine with the load. I'm far from an engineer so maybe not. IDK. Rust is going to be a BIG enemy here since there is no good way to see if it is in there.
If you want exact tube lengths I can get you those since I have a few spare strut towers laying around.
The stock eye bolts are much shorter than the SCP units so I doubt they would work as well. I have several set so I can get you exact lengths on those too.
Also the ID on the OEM eyelet is larger than the SCP unit.
I do have a pretty good idea on how to space the eyelet down and add strength. However I'm in bodywork mode for now so it will be a bit before I have time to mess with suspension again.
What would be really nice is moving the mounting for the shock up higher so there would not be clearance issues and you could lower the car more and gain both camber and camber curve. That would be much harder but more fun.
I tried to get Andrew to come in to this disscusion but he is in Japan and is blocked from the site. Boo.
Kevin
I can answer this easily.
Running race tyres, the stock eyebolts will crack loose every year of autocrossing with monotonous regularity. If they don't crack then you aren't trying!
The inner fenders of my car look like the heliarc equivalent of a spiders web. These days we're welding the welds !
No calculations required...
Running race tyres, the stock eyebolts will crack loose every year of autocrossing with monotonous regularity. If they don't crack then you aren't trying !
Couldn't you cut the welds out from around the old tube, and weld reinforcement plates in around the holes? Then you'd have something a little thicker so you can get a meatier weld?
Might not be worth it to the occasional track goer.
