tsunari
- 1,031
- 35
- Feb 12, 2003
Jessup,
Maryland
Thanks for the drawing, that's perfect. I'm still trying to remember what I saw back in 2008 or whatever when I installed these. I may investigate replacement bushings prior to dissassembly and just replace whatever I find in there since it's my daily driver.
I figured the distortion of the rubber was dependent on how tight you snugged up those bolts that go through them - not that I'm arguing, I'll defer to the goblin gladly, but if the bushings were bonded to the inside of the anchor bolts then how would SPC expect them to be removed for lube? I'm probably just being thick. Can we all agree, at least, that the bushing was red?
Also, who all lubed theirs prior to installation? Any bushing noise? Long-life? Shortened life? Excessive dirt build up?
Nope, no red here. Just black rubber stock looking bushings. The only red I had was the dust boot for the balljoint. Perhaps you got an earlier/later model where SPC changed the bushings out? There was definitely no lube to be put on mine.
