2g slave cylinder
i am pretty sure it will work. Are you sure about the size differences. I went to auto zone and they show the same part number for the 1g and 2g slaves. Oh and i measured every mitsubishi slave cylinder inside diameter. Most were .810'' (13/16") with the exception of the 3000gt which is .750" (3/4"). It is possible that the OEM slaves are different diameters though. In any case i would suggest using a .750" if you are using a clutch with a heavy pressure plate.
Drifter27_04 said:
Can anyone tell me if the 2g slave cylinder will work for a 1g?
2g bore size= 1-3/16"
1g bore size = 3/4"
Where did you see a 2g slave that was that big? I thought they were all the same except for the 1g non-turbo.
