Resolved 2G Removing crankshaft bolt
Josedsm
Apr 16, 2020
North Las Vegas, Nevada
Does anyone know how to take this bolt off I'm tryna to do the balance shaft delete its a 6bolt 4g63t
Your picture seems to be upside down. Also there is no indication of which out of the 30 bolts in the picture you are talking about. But if it’s the one that holds the timing sprocket to the crank snout and has a 1/2 drive in the center you just stick a 1/2 impact on it and make sure it’s in reverse and squeeze the trigger. If you don’t have an impact take the oil pan off and stick a wooden hammer handle between the crank and the block and use a breaker bar. Or have a friend hold the other side where the flywheel is while you turn it.
-Daniel
Solution
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
