Resolved 2G Oil filter housing line routing
98gstJames
223
43
May 25, 2022
WInchester, Virginia
Alright so I put the motor back in the car and I’m hooking up the lines off of the filter housing and I cannot figure out how the line runs(the one that has the hard lines), I’ll post a pic, what I’m basically asking is does it go under a mount or how does the line actually route? I should have taken a pic on how it was in the car but I also went through and replaced the hose so I might have cut the hoses just a little bit extra so I’m not sure if maybe I just have a little bit extra hose so maybe it doesn’t want to fit right, I’m just confused and also the line that I circled I’m confused where this goes, I thought it went to the turbo but I just want to be sure.
Solution
Heres a diagram I colored in to make comprehension easier. The blue line connects to the block with a banjo bolt, the line you circled is the blue line in the picture that connects to the turbo
Solution
Man thank you so much, I kept searching for the exact routes of each line but I couldn’t find an actual diagram that showed every line, I’m definitely gonna be able to get the car all the way put back together today now
No problem. I had the same issue and the black and white diagram was confusing me, so I decided to color in the diagram in my service manual. Happy to help
  • For sale Evo 8 steering wheel with dsm adapter welded on.
    Evo 8 wheel with welded adapter for dsm
    • 98TalonPandaTSI
