2g mas on my stock 1g
Status
Not open for further replies.
z24frank
370
Nov 26, 2007
san diego, California
I want to put a stock 2g mas and intake on my 1g.I know I can get this set up pretty cheap and want to know how my cars going to run if I do this with a stock set up?
I second that just hack your stock mas to lean it out a bit. just take out the lower honeycomb.
What size injectors do I need,and what else to make this complete or is there a better way to get more air on a budget?
Funny story I swiched to a 2g maf on my 1g and then shortly after my ecu went out. The ecu had nothing to do with the maf change, it just went out. So I got a automatic ecu from a friend which obviously compensates for 390cc injectors. I went to tune the car with the AFC and a wideband and I ended out zero'ing the AFC out because the ecu matched the 2g maf perfectly.
Idk your budget but larger injectors include a new fuel pump, safc, and afpr. If you're running stock you are better off doing some other things because injectors will get you no power on a stock setup.
Status
    • Sdcryan1
