Resolved 2G High Rise Wing location placement
If you take the plastics in the trunk off you will see the mounting points already marked under the hatch ready to be drilled through.
All the points for mounting the wing are already there. stock location are pre drilled for low rise, high rise and talon wings
I put a low rise eclipse spoiler on my 95 Talon Tsi and the mounting points were there for it on the hatch.
Yes but on my 95 GSX there is no high rise holes (as there was no high rise in 95-96) but as a talon and eclipse are the same there will be mounting holes for both wings of those years.
BTW going from a 3-piece low rise to the whale tail makes for about a million holes to patch. Make sure to patch those the right way.
I looked under the plastic on my 95 gst and didn't see anything. Ill look again to be sure. Wanting to put the high rise on it.
I had to install my high rise spoiler on my carbon fiber hatch after I bought it, very nerve racking. Measure ten times and cut once or measure once and cut times to get it right, basically if you end with four holes and it bolts up you did it right. LOL
There are reference holes that give you a general idea of where to drill but it won't get it perfect, here's a shot I took during the install so you can get a reference point of where to look under the hatch plastics. If you still need help I can get a shot of the underside so you know what holes to line it up with...
