2g FWD fuel pump assembly
Bubbadsm
31
3
Jan 5, 2024
Williamsburg, Virginia
I’m curious to know if 95 fuel pump assembly matches up with 99 fuel pump assembly? I have to replace my assembly and noticed my fuel pump has two connectors on top of the pump itself but when every assembly I see only has one connector on top. Is there a difference between the two ?
Yea I know that second sensor is for the fuel pressure. I’m just trying to see if I have to swap that sensor to the other pumps I seen
The plugs are different so if you can swap them you'd have to. I didn't try to swap them so I'm not sure if a guy can or not. I can double check tonight. If I remember correctly the 97 return line/and or vent was in a different spot from the 95. Don't quote me on that since it's been awhile.
I’ve not seen new replacements for the ‘98-‘99 models available anywhere. You might try posting a WTB ad in the classifieds for a good used one.
