2G 2g Eclipse Spyder power lock diagram?
ryan4269
52
6
Oct 11, 2021
abbotsford, BC, Canada
My lock signal to the actuator is constant. Having a hard time finding any kind of wiring diagrams and I'm quite confused with the relation of the relay towards the back of the car and the relay behind the stereo.
The front relay clicks on as soon as the battery is connected, which locks my door. So I think my relays are fine as the back one also clicks with several functions like unlock, lock, and when the battery is connected.
The front relay only clicks when the battery is connected, does the front relay only send a lock signal? But the rear relay also seems to as well.
I plan to just run a new wire to the actuator but I can’t find where it leads to. Something funny is previous owner had a generic actuator replacement in and wired it back all the way to the other door connecting it to that actuator. When whenever this short happened it melted half of the actuator away and I bet put up a total smoke show.
the relay in the rear is for the keyless entry
if you need the electrical manual 'n shit, take a looky HERE
what a jackpot, thank you so much!
