2G Custom Fog Lights
Phantomdmod
Supporting Member
53
77
May 24, 2019
Switzerland, Europe
The round fog lights are good, but i decided to make something else.
I like it 😁.
How did i get there? Maybe someone has the same idea or is interested how i made it..
First i started with the oem part , tried to make it fit.
I was not very happy with that , plan was to carbon overlay arond the lights ..
So i went another route. I have a friend in italy he makes beautiful 2G carbon parts.
Simone Trippini
Feelfree to contact him for any part , he also makes custom solutions. I ordered 2 carbon cover.
I also found the cover for my lights, i use wheelen 500 series.
(who knows wheelen, knows what comes in the end 😂 but you will see later)
I cut it and insert the light cover.
Test fit. Not bad but the problem was the lights pointed to the side.
I knew i had to make it straight..
I found a good piece of plastic, cut it to the right shape.
With hot air i fold the edges. Warm up and hold it on the part.
Turned out perfect 😋
It had to be black, painted it Also painted the carbon plate with clearcoat.
Now it was time to glue it together, took a good body sealant.
Thats it 🥳
You could use any light with the right dimension. I took the wheelen for fun reason 😄 , they are blue and red 🚔.
Switzerland is very strict, how the heck you going to be legal with these? Or do they go white also at a touch of a button?
Love your work. My only problem is that with upgraded engine mounts the car's vibrations would make these shake all around. What does your output look like?
Thanks. These are LED lights vibration is not a problem for it..
Got any insight on that grill? Looks awesome!
It's a grill from grillcraft. I modified it to move it a bit more to the back.
Unfortunately it has been discontinued..
😄 Oh yes unfortunately its very strict here. But its not an option for me to do nothing..
At the inspection I cover it. They have 15 min to check the whole car, there are more important stuff.
That would be great to switch to white, but this model is just single color.
😄 Oh yes unfortunaly its very strict here. But its not an option for me to do nothing..
At the inspection i cover it. They have 15 min to check the whole car, there are more important stuff.
15mins! How can they be strict but so quick? Seems odd that, the UK MOT is about 45 mins - 1hr and they go through everything.
😄 Yeah its crazy..
They know exactly were to look.
If something is suspicious, they look closer.
But if you cover something, they most likely dont see it because of the short time.
