2G 200k Eagle Talon Thrust Bearing replacement?
TheDude236
5+ Year Contributor
306
236
Mar 15, 2021
Huntsville, Alabama
Hello again! Of course, now that I’m in the process of repairing the car, my mind began to wander. My eagle talon has 200k miles on its motor, and I am 99% sure the previous owners never rebuilt the engine. So, that means its time for thrust bearing replacement right?
I wont even have anywhere close to the amount of money to buy a new motor (7-bolt or 6-bolt) for at least a year, and unless someone on these forums replaces the thrust bearings for cheap, I’m also gonna have to replace them myself.
The reason I’m posting this is to decide when to do it. I need to drive this car for at least the next month, then I have 3 months afterwards to replace the bearings before I need to drive it again. Or is it even worth it to replace them if they have gone this long? I don’t know what to do really, looking for some crankwalk experts on this one. Thanks guys!
I would suggest you do not assume there is a problem unless its part of a maintenance schedule or you have objective data to support a problem. You will drive yourself crazy thinking about what could be wrong instead of enjoying the car. Bearings can be killed at a few miles or go hundreds of thousands. I've seen above 250k on a stock 2g bottom end and still going. For those that are familiar this was not a split thrust bearing.
If it ain't broke don't fix it! Some of the best advice from ASE Master Techs. Stay on top of easy things like regular maintenance.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
