2 questions for you guys :)
99boostedgst
91
Nov 5, 2011
wichita, Kansas
First one is when under boost it studders a little but still boosts but its not a clean rev its a jumpy rev. Yes I have 1050 CC injector no I don't know if I have a bigger fuel pump, just replaced the plugs with e3's at . 32 gap and new wires. (At 10lbs of boost about to 15 after I do the harness crap
Second is in having tail light problems can replace fuse go drive with head lights on put on a turn signal and press the brakes and it pops the fuze, any suggestions of what's going on? Harnness screwed? If so I have a harness outta a 99 that I can use.
And sorry the last one is I just tuned my ecu and now its starting to stay running for a second like the ecu is running a little longer then purpose to after key is off. If I use my 99 ecu will I be running into trouble Sence it's a 95? And will my tune be gone?
Thanks
dustin
I would test for boost leaks and check to see what pump you are running.
What gap would you put it at? For 1050 CC injectors stock fuel rail, 57trim Garrett and 15lbs of boost?
And any help on the wiring harrnesses? Any clips that will let me replace a whole section at once?
dustin
Make sure this hasnt happend to your harness..
Yes those are bare wires showing.. I have no idea how long theyve been this way.. Noticed it last month.. Had the car for 4 years.
484357[/ATTACH]"]
I checked my harness but haven't went past the antenna motor LOL ill check it out though, but I have alot of wires on the front that was messed up on the front, did you lose tail lights when you hit turn signals and brake lights together?
